Hi Mike,
Your best resource is the National Instruments
Measurement and Automation Explorer (MAX) software utility that ships with your GPIB board. To find this utility from a Windows computer, choose Start -> Programs -> National Instruments -> Measurement and Automation.
Once the application launches, choose
Devices and Interfaces on the left-hand panel. If correctly installed, the GPIB device should appear listed here. The type of interface should be listed in parentheses next to the device name. You can also right-click on the device and select
Properties.... The GPIB interface type should also be listed at the top of the Properties window.
Here is a link to a tutorial on NI's Measurement and Automation Explorer utility:
Using Measurement & Automation Explorer 3.0 to Configure Your IVI System.
Have a great day!
Kileen Cheng
Applications Engineer
