You didn't specify what version of NI-VISA you were using, so I wanted to make sure that you were using the latest from our website 3.0.1 from here: http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C0E91?OpenDocument&node=132060_US
Also, if you are using a National Instruments 488.2 card, please install the latest version of 488.2, version 2.1, from www.ni.com/support/gpib/versions.htm
I'd like to know exactly what your query string is for FindRsrc. What does Measurement and Automation explorer see as valid instruments on GPIB0 when you get this to occur? Are you using any other GPIB/HPIB cards in your system? Do you have any Passports enabled in Measurement and Automation?
Further, it would be helpful if you could
get it to the point where you can force this to occur, but I understand that could be difficult, so we'll work with what we've got.
Scott B.
