CSZ and EZT-430i controller
Hi to all!!
I'm really new in this community but not so new LabView, so I hope this question is not too banal.
I'm usic a CSZ Microclimate chamber, they use a new controller instead of Watlow F4. It's called EZT 430i. The question is easy,  (!!) Have anyone used and controlled it from LabView??
On CSZ site I've found a basic VI module (Modbus RTU Serial Communications and EZT430i Serial Communications) but they are not documented and it's quite hard to use and understand.
Can someone help me? I must integrate the chamber (Humidity and Themperature) with external instrument to have stress measurement of electronic device.
Rino
(6,161 Views)
Hello Rino,
I have never used an EZT 430i with LabVIEW. I can't help you in that issue. Why don't you try to contact NI support?
About the basic VI module you found, can you link it?
Which OS is installed on the EZT 430i?
Greetings,
Dagaror
(6,045 Views)
Hi Dagaror,
Thanks for your reply.
I've already asket to NI but no answer at the moment
Here is the link to the page and driver: http://www.cszindustrial.com/Customer-Support/Software-Manuals.aspx
Test Chamber Controller Manuals - Cincinnati Sub-Zero <script src="http://www.google-analytics.com/ga.js" async="" type="text/javascript"></script> <script src="/resources/libraries/jquery/01_09_01/jquery.js?cdv=28" type="text/javascript"></script> <script src="/resources/libraries/jquery-migrate/01_02_01/jquery-migrate.js?cdv=28" type="text/javascript"></script> <script src="/resources/libraries/jquery-ui/01_10_03/jquery-ui.js?cdv=28" type="text/javascript"></script> <script type="text/javascript">// var _gaq = _gaq || []; _gaq.push(['_setAccount', 'UA-1380015-1']); _gaq.push(['_trackPageview']); (function() { var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true; ga.src=('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js'; var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s); })(); // </script> <script src="https://secure.ifbyphone.com/js/ibp_clickto_referral.js" type="text/JavaScript"></script> <script type="text/JavaScript">// var _ibp_public_key = "0e5a69119c3163743baf314112574cd0df0e2e6d"; var _ibp_formatting = true; var _ibp_keyword_set = 66584; // </script>
The EZT 430i is a Win CE controller
Ciao
Rino
(6,038 Views)
I don't see where NI would be of much help with another vendor's hardware or software. They, of course do provide modbus libraries but you'll need documentation from the vendor on their implementation. What exactly are you confused about with their example VIs? What have you tried? You'll have to do much of the work yourself since you are the one with the actual hardware.
(6,035 Views)
