04-07-2014 03:43 PM
I have found many very incomplete information on IVI COM adapters and the way they work. Most articles or forum thread I found typically include a "magic" step that I can't seem to overcone on my own, hence my posting here.
What I would like to know is this:
1. Say, I have an IVI C driver, is it possible to use those "IVI COM adapters" in a way that I can use only the IVI COM specification (in other words, have an IVI COM wrapper for IVI C)?
2. If so, could anyone provide me with advice/guidance as to how I should proceed to achieve this?
The information I could gather seemed to me that this works the other way around. To be clear, what I want to do is download an IVI C driver and find a way to use it using the IVI COM specification (if at all possible)
Solved! Go to Solution.
04-08-2014 08:15 AM
The IVI-COM adapters are used to pass information from the IVI-C class drivers to the IVI-COM specific driver. You need IVI-COM adapters only if your application is written using IVI-C class drivers and you only have access to IVI-COM specific drivers (instead of IVI-C specific drivers).
NI doesn't have a tool to create IVI-COM wrappers for IVI-C drivers. You should probably contact the instrument vendor to check if they have IVI-COM driver for your instrument.
04-11-2014 03:35 AM
Thank you for your help.
