07-29-2011 04:26 PM
Hi everyone,
i`m trying to read a digital bits from Agilent u2531a DAQ, using a digital input, but i want to read
these bits according to a trigger signal.
Can anyone give a tip or an example?
08-01-2011 02:34 AM - edited 08-01-2011 02:35 AM
I found a link on agilent site with few examples about triggering and acquiring data with u2500 series devices:
http://cp.literature.agilent.com/litweb/pdf/U2541-90011.pdf
If you have further questions about acquiring data with agilent device please contact Agilent technical support.
To communicate with agilent device through LabVIEW I recommend to check GPIB-VISA example in example finder - to detect and work with your Agilent u2531a you need to change I/O Name filtering of VISA GPIB Resource (right click on the drop-box in front panel). All you need to do is to check the box in front of USB Test and Measurment instruments.
Gregor Cerne
08-01-2011 09:28 AM
There is a LabVIEW driver available for this model on IDNet
