Agilent N5763A driver
I try to controll my Agilent N5763A source with LabView.
I'm searching for a driver but I can't find a good one.
Is someone here who has a link for me?
How can I install the driver?
Best
WEni
(3,686 Views)
What wrong with the drivers you can find here
(3,671 Views)
I already tried to install the one which is ceritified by National Instruments.
I opened the the exe-file but LabView told me i need a program called Compliance Package 8.1.
Is this program not part of LabView15?
I don't know how to install this driver because the last one I installed for an other device was only to copy into the instr.lib folder.
(3,664 Views)
Go into MAX and check under Software to see which version (if any) of the IVI Compliance Package you have installed.  You may have not installed the right driver or something in order to have the Compliance Package.
GCentral
(3,659 Views)
It's probably referring to the IVI Compliance Package, which is listed along with NI VISA as a requirement for the driver software. You can download it here.
The driver installs from a self-extracting zip file. After installing the requirements, just run the executable and follow the prompts. It is possible you will need admin access to install it.
Steven Gloor
Staff Customer Engineer - CTA, CLD
(3,657 Views)
Thanks for the fast answer.
I installed the driver and the Compliance Package you showed me.
The only problem I've got now is that there was no vi with the driver which can change the current of my source.
I only can change the voltage with these vis.
Do I have to create a new vi by myselfe or is it possible to change the one for the voltage?
Greets, WEni
(3,621 Views)
