11-05-2015 10:39 PM
11-06-2015 12:12 PM
Thank you both very much for your replies! Unfortunately, I'm still getting the error. Below are my current regional settings. I also tried unchecking the "ignore local decimal" setting in LabView options (and restarting LabView), but I'm still getting the error.
If it helps, here is the error I'm getting from the "Configure Pump" VI in LabView:
Once again, thanks in advance for your help!
11-06-2015 12:15 PM
11-06-2015 12:44 PM
It seems to be the same error that was fixed by changing the decimals where the timeout is coming from the Configure Pump VI. All the other included VI's with this driver work just fine. I can initialize and turn on the pump, but I just can't configure it.
11-06-2015 12:53 PM - edited 11-06-2015 12:54 PM
Two completely different error codes and messages. How do you figure that it's the same error?
11-06-2015 12:58 PM
If I change the regional settings back to commas, it will give me the other error code. Would that be more helpful?
11-06-2015 01:07 PM
12-05-2015 12:56 PM
I would love to talk with someone that has gotten these pumps to work on labview. I am looking to purchase a few 1100 series pumps but would like to get some questions answered first.
12-06-2015 02:00 AM
have you looked through http://kau.diva-portal.org/smash/get/diva2:576273/FULLTEXT01.pdf here they constructed an HPLC with the ag1100 driver.
They shared their developments, but the links they provided are unfortunately not available anymore. I will therefore share them here.
password is: OnlineHPLCexjobb
when you acquire the pumps, i will suggest that you opt for the permanent ip configuration, then you do not need the "bootstrap" that is described in the driver documentation.
otherwise it should be rather straight forward.
Kind regards
12-06-2015 08:08 AM
Hi there!
I got them to work, it is my paper and my files that are linked by Rolri just above this message. Unfortunately it was a couple of years ago so I don't really remember all details but I will try my best to answer any questions you may have. The paper itself might not be of much use to you since it is motsly focused on other stuff than LabView programming, but download the files and try to make some sense of them. They are quite messy and there are probably much better ways of doing things, but they did the job for me 🙂
Rolri: Thanks for uploading the files here since my original hosting seems to have died 🙂
