02-24-2015 12:40 PM
I am trying to instal the required software to Sb rio 9606 using ni MAX.
However this message is being prompted:
I would be grateful if you guys can be of any help.
Thank you
Keshav
02-24-2015 02:31 PM
Do you have LVRT installed on your host?
02-24-2015 02:36 PM
Thank you for your reply.
Is this what you meant by lvrt?
Thank you 🙂
02-24-2015 04:02 PM
LabVIEW Real-Time not LabVIEW RunTime Engine
02-24-2015 04:20 PM
Can't tell from your screen shot. You will need to expand the LV section. It should look something like this.
02-24-2015 09:20 PM
Yes i do have labview real time.
Steps i have taken:
1. Install Labview 2013 (completely with all modules)
2. Install NI RIO driver
Any clue where i might have gone wrong?
Thank you very much
02-25-2015 08:10 AM
Hi keshavsew,
What version of the NI-RIO driver did you install? If you have the RIO driver correctly installed on your host PC, you should be able to install Real-Time software to your sbRIO target, as described here. This process should be the same as installing software to a regular cRIO.
Andrew
02-25-2015 12:43 PM
The error you are getting typically only happens if you have something installed on your target that isn't available from your host. If you feel that you have everything that you need already on your host the safest thing to do is probably to format the target from MAX and then proceed to install what you need.
02-27-2015 06:01 PM
Thank you very much for your reply.
Indeed, the problem was solved by formatting the device
09-13-2015 10:37 AM
I have the same trouble.
I tried to restart the ni single board rio 9632 in the safe mode :
to reformat the device, but the sensor motor keeps rotating the sensor, and I have to turn off the MASTER to stop it. In addition to that, the POWER flashes several time (following the rotation rithm of the sensor motor)
Do you have an idea about the problem ?
I have Labview CDs, I can't understand why do I need to install NI RIO, I thought it is included with the software ! anyway I downloaded the NI RIO driver from the website, but it is very slow, is this normal ?
thanks in advance.
