I think we may have found the issue here. Intel published app note at the following link
ftp://download.intel.com/design/network/applnots/30037501.pdf
The app notes says, among other things, that
"If an external PCI device has non-prefetch memory and requires either
a 16-bit or 8-bit read, there is a possibility that the device will not
respond correctly to the IXP42X product line and IXC1100 control plane
processors’ memory reads. This is because the processors always perform
a 32-bit read to the non-prefetch memory region specified in register
PCI_NP_AD."
and
"For more information on 8-bit memory read transaction implementation, contact an Intel representative."
As I said in a previous post, accesses to the 4882 registers should be
made using 8-bit register accesses. Accessing registers using a 32-bit
access will have unreliable results.
In the same app note Intel does provide a workaround to perform 16-bit
accesses; however, it requires a significant schematic change.
Please review the app note and let me know your thoughts. There may be
some other workarounds but none will likely be trivial to implement.
