01-27-2014 01:58 AM
I'm trying to define ACQUISITION_START_TIME to Tektronix DPO3034 through USB interface with CVI.
I managed to install the driver and can communicate with the oscilloscope.
When I write the delay value (3.5334E-005) this is what i get from the Spy:
1. IviScope_SetAttributeViReal64 (DPOScope, NULL, ACQUISITION_START_TIME, 3.5334E-005)
Process ID: 0x00001534 Thread ID: 0x00000874
Start Time: 17:29:42.456 Call Duration 00:00:00.015
Status: 0 (VI_SUCCESS)
That means that the right command was passed.
But... the delay in the scope comes with 0.4us resolution. That means that i can get ACQUISITION_START_TIME values of only 3.56E-005, 3.6E-005 etc.
This is what I get in the spy with GetAttribute command imeddiatley after the above SetAttribute command:
4. IviScope_GetAttributeViReal64 (DPOScope, NULL, ACQUISITION_START_TIME, 3.56E-005)
Start Time: 17:34:11.995 Call Duration 00:00:00.016
(The actual delay on the scope screen is also 3.56E-005...)
Thank you for your assistent!
Solved! Go to Solution.
01-27-2014 04:38 PM
Does the scope support the delays you want? Do you know that the scope can be programed by other means to accept that value?
01-28-2014 01:04 AM
Yes, the scope supports the delays I want when I define them manualy or with stand alone program based on LabView (don't have access to the code...)
Just to mention that the CVI program does what I need on 3 other scope models.
01-29-2014 12:48 PM - edited 01-29-2014 12:53 PM
Can you compare the NI-SPY logs for the what is sent using the LabVIEW (successful) and CVI (unsuccessful) drivers? are the two drivers writing to the same atributes?
I also wonder if there is precision setting for the delay that must be set prior to specifying that delay. You may want to look several commands back in the NI-SPY logs to try and find such a precision setting. The idea of a precision setting is pure speculation on my part.
just to confirm; The labview driver for DPO3034 functions well but the C driver for the same instrument is demonstrating the undesireable behaviour?
As a work around you could call the labview code from C.
02-06-2014 03:04 PM
