04-07-2016 02:27 PM
I have an ancient 183617G-01 PCI-GPIB card pulled from a PC running XP.
It is presumed that the card was working when the PC was taken offline, but I can't be certain since I wasn't here at the time.
I installed the card into a Dell Optiplex 7010 desktop PC, and the PC will not boot.
I have even updated the BIOS to the latest version on Dell's website.
I have NI-488.2 version 2.8.0 installed and per the ReadMe file, this card is supported.
Anyone get this card working in Windows 7?
I saw another post on this forum about this card, but not resolution.
04-08-2016 11:25 AM
Hey Intens,
I'd suggest some basic troubleshooting to try and identify where the problem is. Have you tried the card in a different computer? Have you tried to boot the computer without the card? Can you boot into safe mode?
In general, yes, PCI-GPIB cards can work in Windows 7. Also, 488.2 version 2.8.0 is a pretty old version, the newer versions of the driver also still support the PCI-GPIB, so you might want to upgrade your driver as well. I doubt that's causing your PC to not boot, though.
Cason
Applications Engineering, National Instruments
04-08-2016 03:46 PM
@Case_in_Point wrote:Hey Intens,
Cason
No, I don't have another computer to try.
The computer boots without the card.
I haven't tried Safe Mode.
NI-488.2 2.8.0 is necessary because we are running LabVIEW 8.5.1
04-11-2016 04:59 PM
Hmm, not being able to try the card in a different computer makes it tough to troubleshoot. If you have any other PCI cards installed in the computer, do you encounter problems? Does your motherboard have multiple PCi slots you could try? Bad PCI cards can absolutely keep your computer from booting, so the ultimate goal is to determine if the card itself is damaged, or if there's something weird going on with your computer.
Cason
04-12-2016 11:06 AM
I found another NI PCI-GPIB card.
This one is the 183617J-01. And it boots.
Looks like it has newer firmware.
04-13-2016 04:04 PM
The different letters at the end of the part number typically indicate a change in component manufacturer. There aren't any software compatability changes between revisions; the two revisions are completely register compatible. It definitely sounds like the card itself could be compromised, but without being able to try it in another computer, there's no real way to tell for sure.
Cason
04-14-2016 08:14 AM
I will keep that in mind.
Thanks.
09-17-2018 10:18 AM
@Intens ha escrito:
nese cito esto
