05-28-2015 06:34 PM
NI VISA driver was working fine until I installed a Tektronix driver .It threw the following error from then on
"1073807343 ERROR NI VISA write in"
So I uninstalled the NI VISA driver to install the new version with the bug fixes .
But I was not able to install the newer version NI VISA 14.0.1 as throws the following error
Unsupported version of NI-VISA detected
A version of NI-VISA that is not supported on this operating system has been detected. You must cancel this installation and uninstall the older version before continuing. Visit ni.com/info and enter the Info Code CleanVista for more information."
But I have uninstalled the older version already . How do I fix it ?
05-28-2015 07:56 PM
05-28-2015 08:01 PM - edited 05-28-2015 08:02 PM
I installed Tek Driver for an Oscilloscope for Labview .I uninstalled NI VISA (older version ) , because when I tried to instal the new version , it sent an error message to uninstall older version as it is preventing the installation of new version . OS-Windows 7
05-28-2015 08:04 PM
Which registry should I clean up ?
05-28-2015 08:13 PM
I'm wondering if the driver installed the Tektronix VISA. You should uninstall that before installing the latest version of NI VISA.
05-28-2015 09:01 PM
06-01-2015 03:09 PM
Cleared them manually and it works .Thanks !
