1073807202 error in Keithley 2401 SMU
Every one.
I am using Labview 2012. I am trying to interface Keithley 2401 SMU with laptop via Keithley-GPIB KUSB 488B. When I am trying to run the program, it is indicating error 1073807202. I have reinstalled all the labview software, NI-VISA (latest), drivers and 2401 library files, but the problem remain as the same.
Can any one hepl me. I need to fix this problem as soon as possible as I need this for my research purpose.
Also can u suggest me the SOP (Standard operating procedure) sequence for installing labview, NI-VISA and instrument driver.
Thanking you
Avishek Das
(5,021 Views)
The error is probably due to your use of a Keithley controller instead of one from NI. Have you checked with them about using their hardware? How does the controller show up in MAX?
(5,012 Views)
Have you solved the problem? I use the same keithley 2401-kusb-488b with the same error. I can;t run any of the VIs.  Have you tried with rs232?
(3,994 Views)
I have the same error code. Could you solve it? Please can you help me?
(3,209 Views)
Hey Everyone,
Since we are working with a GPIB based instrument, you are also required to install NI 488.2 drivers. This is different from NI VISA driver.
Another major cause of this issue if the VISA driver gets corrupted during installation.
Please refer to the Knowledge base article mentioned below for detailed description on install instructions of VISA drivers.
http://digital.ni.com/public.nsf/allkb/10C6C0FBB8E7BD4486257850006CE8FF
Also, another issue that was reported on similar lines is mentioned in this forum post
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Error-1073807202-Missing-Code-Library-in-VISA...
Thanks & Regards,
Raghunandan N V
AE - NI India
(3,192 Views)
