05-07-2006 06:15 AM - last edited on 12-01-2011 05:11 PM by JordanG
Hi Folks
I want to build industrial equipments like tanks/heaters/valves/motor or mixer/RTD/Level sensor in LabVIEW
i could find tanks/RTD but i couldnt find the rest.
After building these things i want to control the action of this total process by PLC Siemens S7 200
i dont have any idea about this thing
Let me know how it can be controlled whether by using RS 232/ RS 485 or OPC server
if so is OPC server is a software...where can i download or where can i buy
If any body could help me i will be happy
05-07-2006 05:47 PM
07-17-2006 05:15 PM - last edited on 12-01-2011 05:11 PM by JordanG
I have S7200 PLC and its OPC server to interface LABVIEW
Should i program anything in LabVIEW
or just build and interface the PLC
07-19-2006 03:06 AM
07-20-2006 05:10 AM
07-21-2006 03:09 AM
07-25-2006 08:56 AM
yes ryan i could see examples about OPC but i dont have any clue on that stuff
i have the OPC PC access for s7 200 right now
but i dont know how to start ...i dont have any knowledge on this
i just want to do this project and leave off. so let me know what should i do to control the flow of tanks simulated in labview by PLC
pleaseeeeeeeee...........reply me as soon as possible
many thanks
07-26-2006 09:00 PM
08-04-2006 10:19 AM
yes i have programmed plc
when i access the program in PC access the value is bad
the same is when i test with the server explorer also
but the program is running properly with external inputs
what can i do ryan
my program and my pca file for ur verification
08-07-2006 10:43 PM
Hi Nura,
Are you still using the OPC server? Is it up and running? I would first make sure that the OPC server is working correctly, and then go from there. I know you said you haven't really used an OPC server before, but there is lots of information online that should help you through it. Take a look at the following link for a starting point:
Connecting LabVIEW to an OPC Server through a DataSocket Connection
Justin M.
