05-06-2016 10:43 PM
I have a problem when trying to configure communication between cRIO 9030 and yaskawa SGD7S servo drive through etherCAT.
My project has detected my servo drive as a slave in cRIO master.
I choose unbundel axis in axis manager....
when I deplloy all, there is no problem.
but when I try to running in a simple program... it allways has an error.
I also try interractive test panel. it also not working...
would you like to give me an advise...
05-10-2016 04:03 PM
Hello ade45,
What error message are you seeing whenever you run your program?
06-26-2016 03:50 PM
I think your slave uses CANopen over ethercat (CoE), for what i know NI does not support it.
I had simaler isues with a similar drive, it turns out to be also CoE instead of true Ethercat.
I never did manage to get it working. So i think your drive is not compatable.
