09-29-2014 12:52 PM
Attempting to communicate thru a Molex devicenet usb interface module (DN4) Using the drivers and simple demo example from Molex, i can bring it on line(connection established) but am unable to communicate with any devices either poll or explicit . In case of explicits, not sure of how connections to the code interfaces made (ie- service id, class, att, data,)
Using their software utility, am able to send and rec .
Was wondering if anyone has had experience with this device and might have code willing to share, any version Labvview? (or screenshot would be fine)
Thankyou
Best Regards
09-30-2014 05:21 PM
Hi amazed,
Unfortunately we do not support the drivers and examples from Molex, so unless another forum member has experience with this, I would get in touch with Molex.
Good luck!
09-30-2014 05:36 PM
Thankyou Joel
Molex provides some unofficial asssistance up to a point, but they use the same rational as you stated in terms of support in this area.
I understand.
Best Regards
02-19-2015 05:32 PM
hi amazed,
i am in same situation as you
were you able to get the device working?. will you be able to share some code or labview drivers for the device?
Thanks in advance
