03-24-2015 06:25 PM
I have a compactlogix that I want to communicate with. is there anyway that I can simulate the PLC in the labview while I am developing the code for it (somehing like NI simulation capability)? or do I need to physically conect the PLC to my comppuer in order to test my code?
03-25-2015 09:27 AM
parissa_wall3,
How are you communicating with the compactlogix PLC? If you're using NI OPC servers, there are built-in tags that provide constantly updating data in a variety of patterns (sine wave, square wave, etc...).
03-25-2015 10:58 AM
I bought the Ethernet/IP toolkit, and I am going to use Ethernet to communicate with the PLC.
03-29-2015 10:05 PM
Hi Parissa,
In terms of LabVIEW EIP toolkit, it supports
That's it. It does NOT support Implicit Messaging Scanner, which is usually what a PLC does.
Using the EIP VI, you can simulate explicit messaging communications with other VI, or a thrid party EIP adapter (using CIP Attribute Get/Set Single).
03-30-2015 11:59 AM
Thanks, I gave up on simulating the PLC and currently I diretly connect to my compactlogix viw ethernet cable. I was able tio run the NI SLC5000 example and it identified the IP that I assigned to the PLC, now, the main question is:
I have to control the compactlogix PLC tusing labview. If I have the desired jobs saved on the PLC how can I load those using Labview? I have the Ethernet/IP toolkit.In the example that came with the NI I can read/write Tags, File number/element number and data. I am not familiar with PLC programming and another professional will program the PLC, however I need to be able to communicate with PLC using my software in order to run the saved programs in the PLC.
04-02-2015 04:41 AM
Hi, parissa,
Looks like you only needs to tell the PLC to do a pre-defined generic task. I guess this would has nothing to do with the specific communication protocol you use.
I think you only needs to implement a loop, or event handler, using which to detect the change of certain flag, marked by Ethernet/IP communication, or Ethernet communication. Then upon detection, the PLC executes whatever it's programmed to do.
