05-26-2014 07:42 AM
Hi, I tried to communicate the Delta PLC with the LabVIEW. But I couldn't interface the both the things. Bothe are working seperately. I was used http://www.ni.com/white-paper/13911/en/ this link for interfacing with the PLC. From those steps, I can see output in "Distributed System manager". But there is no reaction in PLC. Apart from these steps ("Connect LabVIEW to Any PLC With Modbus")is any other steps are there to finish the communication?
Thanks in Advance....
05-26-2014 09:04 PM
If you use Ethernet, make sure the network environment is correctly set up. Was PLC's IP specified when you create modbus?
If you use serial, also check if COM port number, etc. match.
05-26-2014 11:50 PM
in serial everything is OK...Serial port match,baud rate etc., my doubt in How to assign the MODBUS address in LabVIEW... For Ex, I have to switch ON Y0 coil by triggering on M0. So, MODBUS address for M0=002049 and Y0=001281. where I have to put these address in LabVIEW?
05-27-2014 01:02 AM
Yes, I got it. Now i can interface with PLC and VI with the help of OPC server(kepserver)
05-27-2014 09:45 AM
can you post what you had to do so others can find it?
06-04-2014 10:27 AM
hi i am trying to interface delta plc 14ss2 with labview using modbus serial i have tried visa,and opc. the opc server is not showing a driver for delta plc.when i tried visa and drag a bound variable to block digram and run the program an error occured and it says that resourse is valid but visa cannot access it.one more problem do i have to program my plc also and how would plc identify that which bound variable is x0 or x5 etc
06-04-2014 11:25 PM
procedure to interface PLC and LabVIEW:
http://www.ni.com/white-paper/7450/en/
06-04-2014 11:53 PM
Hi..
I want to inteface GSM(with labVIEW) and PLC, My PLC will work in serial port only.
In my PC I have 3 serial ports. before installing the DSC module in my sytem, I can configure the all serial ports..but, when I finished instllation of DSC module, 2 ports does not working among those 3 serial ports. Before instllation,I can work with PLC and I can use other ports. After installations,I cant configure the those serial ports...Herewith I attached the error with this..... Please Help me soon.....
06-06-2014 12:36 AM
When I am interfacing with VI and PLC, its taking too much time for communicating. after that some ime this error also is coming....please guide me with this....
06-09-2014 01:32 AM
Sorry I can not identify how this is related to industrial communication protocols. With which product are you having the issue? Modbus, DSC, GSM or others?
Please post the question under the right board to get replied sooner.
