09-09-2014 03:48 AM
I am currently working on a Veristand Custom Device to read the I/O of several Beckhoff Ethercat modules. So far the custom device is working and I can scan the I/O of all modules OK but now I have the problem that I can't work out how to send the configuration data to the modules. The documentation says I need to set PDO and CoE values over the Ethercat interface but I can't see any way of doing this in Labview.
Has anyone configured a similar system that could offer any advice?
The Beckhoff modules I am using are Ethercat Box EP8309 and EP3314
Thanks in advance,
Joe
09-09-2014 09:30 PM
there are some examples of sending pdo in labview, but I am not sure if they are built into the custom device. I would track down the examples and go from there. Also, unless these are special devices or you need configure them in a one-off way, you typically don't have to send any pdo messages to commuinicate. The driver will take care of that for you.
09-11-2014 08:56 PM
If its possible to set them, it will be in the section "Ethercat references and procedures" section of the help (http://digital.ni.com/manuals.nsf/websearch/1B4474FA3D371FCB86257D0F000C10DE). Try looking at the master and slave device methods. If I remember correctly there are also some super low-level examples that get installed with ethercat.
