I am having trouble sending messages from my NI-9866 LIN Module and need help confirming my setup is correct.
Hardware:
- NI-9174 with NI-9866 Module & CAN Breakout Box
Software:
Steps I have taken:
- Powered all equipment, all indications show devices are properly configured & wired
- Opened and tried each of the NI LIN examples in an effort to capture anything sent using the builtin bus monitor
- I see activity lights flashing during commands on both the mainframe and module.
- When I try to capture any of the Frames\Signals using the Bus Monitor I get nothing.
- So, I then tried dragging the XNET Signal Session I created into a blank VI. It runs, lights blink, no error
- If I turn on the Bus Monitor and run the VI I get the error shown in the attached pic
Shouldn't I be able to capture the frames\signals I send to the 9866 even if the device on the other end does not recognize the message? So before I can confirm if I am creating the frames correctly I want to make sure what I send is being broadcast on my small LIN network.
Any help is greatly appreciated!
