06-06-2011 02:11 PM
Greetings,
I have a PC that I would like to make an NI EtherCAT master so that I can program and communicate with an NI 9144. I would like the PC itself to be the master, I do not want to use anther chassis (cRIO, PXI, etc.).
I see hints that I should be able to do this with LV 2010 RT and NI-Industrial Communications for EtherCAT 2.1 installed, which I have. But I cannot find any documentation on how to get the master set up on my PC.
Are there any tutorials or instructions on how to do this?
Solved! Go to Solution.
06-06-2011 08:34 PM
To use a Desktop PC as EtherCAT master, we would need to set up the PC as RT target at first. The following two links should be able to provide more detailed information about the system requirements and the setup steps:
http://zone.ni.com/devzone/cda/tut/p/id/8239?OpenD
http://www.ni.com/pdf/manuals/371857f.pdf
Now with a Desktop PC running LabVIEW Real-Time OS, we need a second Ethernet adapter to work as EtherCAT master. Please refer to the Supported Hardware section in the link below for our recommended adapter list for real-time desktop target:
The Desktop PC now can work as any other RT controller (cRIO, PXI, etc.) that supported by NI-IndComm EtherCAT driver. You can discover this target in MAX, install the real-time software to it, set the 2nd Ethernet adapter to EtherCAT mode, and use this target in LabVIEW.
Hope it help!
06-07-2011 09:33 AM
Sweet! Thank you for those documents they are exactly what I was looking for. It's clear that I wasn't thinking about this problem correctly.
Thanks again.
Dan
09-25-2011 04:16 AM
We offer a EtherCAT Master Library for LabVIEW, that allows to control a NI-9144 directly from a Windows PC via EtherCAT on a normal Ethernet port. The library can be used to:
- Read and write cyclic process data with a deterministic bus rate
- Read and write configurations (SDO) by CoE
- Download firmware and fpga projects
- Change EtherCAT Bus state
More information can be found here:
http://www.ackermann-automation.de/ecatlv_en.htm
03-26-2012 06:34 AM
I would like to have PC as EtherCAT Master and Development Software is CVI. Can someone give me some guidence.
11-08-2012 03:08 PM
What NI Software I need to be able to use your VIs. I am able to talk Beckhoff Ethercat slaves using their TwinCat Software and a third party network card. Do I need any hardware to use your programs?
12-04-2012 11:23 PM
12-05-2012 08:35 AM
Your question should be answered by what JZhou wrote earlier in this thread. The LabVIEW EtherCAT master driver requires an RT OS running on a PC, PXI or cRIO target. CVI is not supported. Only certain ethernet chipsets are supported for PC ETS Rt targets:
DirkW
12-06-2012 11:26 PM
Thanks for your valuable reply!!.
I m planning to develop a custom application in LabVIEW RT with EtherCAT library on my PC.
So is it possible to communicate to any slave hardware irrespective of the manufacturer from my Master application. ? or is it restricted to only specific slave hardware. ?
Because I want to develop a generic Master application which should communicate to different slaves of different manufacturer.
Chetan.
12-07-2012 08:15 AM
EtherCAT is an open standard and therefore you can use it with all slaves out there if they are compliant.
DirkW
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
