07-07-2015 05:16 PM
I'm new to IEC 60870.5. I need to read data using this protocol.
I have the IP Address of the machine that has access to the data. I guess that is called the Master (?). I was given a document with a bunch of "104 Addresses". I'm guessing those are "IOA"s (?). The same document I mentioned has a couple of other numbers that seem to apply to several of the "104 Addresses". They are labeled "Nr." and "Number". I'm guessing those are "ASDUs" (?). Unfortunately I don't have much access to the folks who actually put that doc together.
One of those 104 Addresses is for a measurement labeled "AC voltage". I believe the value is simply a DBL. To read it I built a VI (snippet attached), except I don't know what to insert where the Question Mark is. Can someone suggest what goes there? I tried using the "Read Parameter.vi" function but that generated error -355269 stating "NI-Industrial Communications for IEC 60870-5: This type of points does not have parameters."
I tried following the examples, but I got confused. Probably just me!
Thanks in advance for any help!
Solved! Go to Solution.
07-08-2015 04:57 PM
Hello AkashSharma,
Which example VIs did you try using? I agree that some of the advanced examples can be intimidating but the general examples are relativity simple. The “Write Single Point.vi” example is concise. I would recommend using that VI as a starting point.
I attached the example files for your convenience.
j_bou
07-08-2015 06:57 PM
07-09-2015 12:10 AM
07-09-2015 03:49 AM
