Industrial Communications
Profinet for cdaq controllers
Does anyone know if the Profinet Slave c-Series module will work on the cDAQ Controllers (with RTOS)?  It is explicitly listed as compatible with cRIO, but I cannot find hard evidence that it will work on the cDAQ Controllers.
Wes
Wes Ramm, Cyth UK
CLD, CPLI
(4,664 Views)
Accepted by topic author Wes_Ramm1
Hi Wes,
The cRIO PROFINET module requires the use of LabVIEW FPGA.  Due to this it is not compatible with cDAQ chassis regardless if they are running a Real-Time Operating System.
Matt S.
Industrial Communications Product Support Engineer
(4,656 Views)
