11-10-2011 08:02 PM
I recently updated my Labview from 2010 to 2011. And then I tried to install the latest Profibus driver (DF_PROFI_II_LV_1.36.2.zip) which I downloaded from (http://joule.ni.com/nidu/cds/view/p/id/2687/lang/e
Normally, this addon should be installed at the following path (C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\addons). However, I did not find it in the"addons" folder of Labview 2011. Did anyone else ever come to this issue? To solve this issue, should I just copy Comsoft.lib in "addons" folder of 2010 to the one in 2011? Anything else I should do?
Zhi
Solved! Go to Solution.
01-06-2012 05:27 PM
I found the Comsoft.mnu in the following folder:
(C:\Program Files\National Instruments\LabVIEW 2010\user.lib
01-09-2012 02:15 PM
I t looks like it detected the LV 2010 version as the current one and did not install anything into 2011. You should be able to copy the files over to the same path mentioned.
DirkW
01-09-2012 06:08 PM
Yes, I just copied the one in original LV2010 to the same path under LV2011which seems compatible as now. Share more when I dig deeply.
02-03-2012 02:20 AM
I did the same thing. But, even though Express VIs of Master & Slave are missing. Can anyone help me how to find out ?
Kantha.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
