01-06-2012 03:42 PM
I have a Profibus card (DF_PROFI_II DP). It was working fine on an old PC. Our IT department need to upgrade PC to a new one, and now I can not get it to work on the new PC.
Both PCs run windows XP. I tried driver for original CD which is 1.32.1 and I tried a downloaded driver 1.35.0. In both cases, windows can recognize the hardware. However when I tried to run Configurator II, the program always shows a message like below:
Anybody can help?
01-09-2012 12:49 PM
First make sure you have the LV RTE 7.1.1 installed if you use this older version of the driver. If you have a newer version of LabVIEW, you should consider to download the lates comsoft driver from our NI download page. Make sure you uninstall all comsoft componets before installing the new driver.
Next make sure you have NI-VISA installed. It should come with your LV driver CD.
DirkW
01-09-2012 01:59 PM
I have Labview 2011 and I just downloaded and installed DF_PROFI_II_LV_1.26.2 and the problem still exists. Any other suggestion?
01-09-2012 02:13 PM
Do you have Administrator Rights on your machine or when you are running the ConfiguratorII?
DirkW
01-09-2012 02:37 PM
Yes, I have Administrator right on the machine.
01-10-2012 08:39 AM
If the error happens as soon as you start the configurator I would think there is a conflict between different versions of the configurator.
Could you go ahead and remove the board from your PC, uninstall all Comsoft components from your machine. Sometimes that might be not only the driver but also the configurator.
Then go ahead and delete the Comsoft folder, reboot and install the 1.36.2 driver.
Then install the detect the board again and try the configurator.
DirkW
01-10-2012 12:28 PM
Followed your suggestion step by step and still having the problem.
And Comsoft Network Configurator search info will say "No device found!", but Measurement & Automation can detect the card.
01-11-2012 08:18 AM
The network Configurator is actually the wrong tool. You should use the Configurator II with your Profibus board. I thought that one is giving you the error?
DirkW
01-11-2012 11:06 AM
Yes, the configurator II is the one I always use in the past and does not work on the new PC.
I am trying to contact with the company in Germany, but the communication is slow due to the time difference.
01-24-2012 01:57 PM
Is there any update from your contact to Comsoft support?
DirkW
