NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
ademedeiros
PXI-8532 Output Supply
Does anyone happen to if the output voltage of the PXI-8532 can be software selected between 10V and 30VDC? Our particular test application requires testing a DNET device at max and min supply voltage.
Thanks!
Active Participant
DirkW
Re: PXI-8532 Output Supply
Yes, the board has a Vbat Input to take external power supply between 10 and 30 volts.
DirkW
Member
ademedeiros
Would you happen to know the difference between the CAN Reference GND and the Optional CAN Reference GND shown in the Datasheet? From my research I believe the only connections I need to make are CAN H, CAN L, and CAN REF GND? My DNET device will have its own seperate supply, im assuming?
Member
ademedeiros
Let me correct myself, what I mean is that I do not need to supply power to the DNET card.
Active Participant
DirkW
Yes, the board doesn't need external power it is supplied internally.
DirkW
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
