Does anyone happen to if the output voltage of the PXI-8532 can be software selected between 10V and 30VDC? Our particular test application requires testing a DNET device at max and min supply voltage.
Would you happen to know the difference between the CAN Reference GND and the Optional CAN Reference GND shown in the Datasheet? From my research I believe the only connections I need to make are CAN H, CAN L, and CAN REF GND? My DNET device will have its own seperate supply, im assuming?
