01-21-2015 01:29 PM
sorry I guess my last post was confusing becasue of the last image i inserted in there. I am copiling this VI. It is larger than one screen so i inserted it here in 2 pages. When I double click on the error it takes me into one of the sub VIs within the SPI API but the VI that I am compiling is the VI shown below
01-21-2015 01:32 PM
sorry, I guess my last post was a little confusing. When I double click one for the errors it takes me to the Sub VI that i pasted on my last post but the VI that I am trying to compile is this one (sorry, the VI is too large so I am pasting it as 2 pages):
01-21-2015 01:45 PM
I can't test this at the moment, but does the error go away if you assign signals to the CS1 through CS9 IO Name controls in the FPGA IO Names constant on your top-level VI? Currently the IO name controls in that constant do not have selections.
01-29-2015 04:15 PM
ok guys, i finally got it allt working 🙂 thank you so much for your help.
Thanks again,
Farhad
03-22-2015 10:41 AM
Could you say, or link to the SPI library used here. I will soon try to implement SPI interface with ni 9651 and i have been looking into how to setup a SPI communication with for eksample analog input chips. I have found atleast 3 different implementations from NI and I am an unsure which one would be best to implement. Is there one implementation which is known as the one to use?
See image below for SPI implimentations found on VI package manger alone. Some of those are the same with slight example differences but still there is many to choose from.
03-22-2015 12:07 PM
Hi again,
I also found this https://github.com/NISystemsEngineering/SPIFramework which seems interesting, but mabye not complete yet?
Regards
J
03-23-2015 11:11 AM
Hi JohmDoe,
I would recommend this API as a starting point: http://sine.ni.com/nips/cds/view/p/lang/en/nid/210637
03-23-2015 02:56 PM
Also, the NI-845x 14.0 driver is available for use with the NI USB-8451 and NI USB-8452 I2C and SPI interfaces.
http://www.ni.com/download/ni-845x-14.0/4892/en/
05-12-2015 08:46 AM
Hi Kyle,
I am trying to do the same thing but I am struggling to follow your instructions. Is there any chance you could post a couple of screenshots showing the process please?
Michael
05-13-2015 09:56 AM
Michael,
What specific steps are you trying to follow and having trouble with?
