10-01-2015 11:09 PM - last edited on 03-08-2024 10:13 PM by Content Cleaner
I downloaded NI-Industrial Communications for IEC 61850 14.0 and tried to activate it using my NI Developer Suite serial number. However, I was told, "The following serial numbers are invalid or do not match their corresponding products."
The same serial number was accepted for activating NI-Industrial Communications for Ethernet/IP, so I thought I'd have access to all the communications toolkits, including IEC 61850. Is this not the case? How can I check which toolkits are covered and which aren't?
Thanks!
10-05-2015 09:51 AM - last edited on 03-08-2024 10:14 PM by Content Cleaner
Hi JKSH,
You can view a list of installed NI software by opening NI MAX and navigating to My System>>Software or by opening Control Panel and Navigating to Add/Remove Programs>>National Instruments Software.
You can also view a list of activated software using NI License Manager.
If you have more questions or if you want an exact list of every product you have access to , you can call in to support at NI. 1-866-275-6964
10-05-2015 02:47 PM - last edited on 03-08-2024 10:15 PM by Content Cleaner
Hi JKSH,
1. The NI-Industrial Communications for EtherNet/IP is included in the Developer Suite, like JDizzle mentioned.
2. The IEC 61850, DNP3, and IEC 60870 toolkit are not part of the Developer Suite.
3. However, you can purchase Electrical Power Suite Pro + Power Utility Protocols Bundle and this has the EPS Pro and IEC 61850 and DNP3.
4. or you can purchase each (IEC 61850, DNP3, and IEC 60870) toolkit separately
