NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
amat
How to write data on the DeviceNET bus,
I’m using LV 2011, trying to measure 16 TC channels, take the readings (°C) and write it to the DNET bus.
The first part is easy and I use the 4353 to read data.
The 2nd part, I didn’t do before, and I’m following an example “Write to DN “ , but not sure about the
  • Configuration
  • Set the 8532  as a slave
  • How often to write
  • Type of data e.g. DBL, U8 or TXT to be sent to the bus
  • Do I use one loop for both the DAQmx and DNET write
If there an example similar to that this would be great.
Active Participant
DirkW
Re: How to write data on the DeviceNET bus,
The 8532 board does currently not support Slave mode. Did you buy the board because you thought it is supported?
In the long run slave support is a feature we would like to add.
DirkW
Member
amat
I'm not sure if I need to set it in the slave ?
So can I use the 8532 to write to the DNET bus , do I use the write VI?
in this application, what should be the proper settings?
Active Participant
DirkW
Yes you can write to the bus. But the current version of the driver has no API, just basic variable support. Have a look at this post to download the beta that comes with API and examples.
http://forums.ni.com/t5/Industrial-Communications/NI-IndCom-for-Devicenet-2-1-API-Beta-is-now-availa...
DirkW
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
