NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
laszku
How to add dll library to application?
I start programmed the CVI a few weeks ago and I have a little problem. I must make an application layer for profibus master device. However I total do not know how to add dynamic library to program, because in another way I get the error: undefined symbol. I know that it very trivial, but I cannot find solution. I have a lib file and also I include file about device, but I still get the error – undefined symbol – can you help me?
Thanks very much for any advice or help
Member
Tamas_Szekely
Re: How to add dll library to application?
Dear laszku,
Are you looking for solutions to connect your CVI application with PLC? Because there are also solutions for that which are easy to use, and to implement with CVI.
If you want to use your DLLs, there are some on-line help, how to import them in CVI.
Basicaly there are two different method to import DLLs:
- static import, when you import the library in your CVI project. The dll will be loaded when the exe starts running. If there is an issue to load the library, you'll be able to get the error at compilation time.
- dynamic dll import, when you load the library at run-time. With this, you get the flexibility to control, when will be the dll linked to your exe in the memory, while running. The disadvantage is, you'll get errors only at run-time.
I recommend you some of our on-line tutorial, how to load DLL into your application in CVI:
CVI Help: Loading Dlls - This says: You cannot import DLLs directly into your project. You need to create DLL Import Library, which can be imported into your project.
To do so, look at this knowledge base: Creating Import Libraries for a DLL in LabWindows/CVI
You might get answers for your following questions at this FAQ page:
FAQ: Using Dynamic Link Libraries with LabWindows/CVI
Some help sites:
Rules for Using DLL Files
Linking to Functions Defined in a DLL From LabWindows/CVI
If you need dynamic linkink, you can get example code with this site:
How Can I Access DLL Functions in a LabWindows/CVI Program Without Including the Import Library in t...
I hope, I could help you to find the way how to import DLL libraries.
If you still couldn't solve the error after studying the links, please provide me more information, where, which symbol is missing, and also the full error message.
The error you get, can be caused by the linker or pre-compiler also, which doesn't find the symbol you requested. Please check the path of your library and dll also.
Best Regards,
Tamas Szekely
Member
jenniferolsen
If your computer is missing a .dll file that it needs to perform a certain function, it will typically send you an alert message to let you know that you need the file before you can proceed.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
