NI Home
Cart Cart | Help
You are here:
Reply
Member
steve_robbins
Has anyone made a program to check to see if firewall settings are allowing communications on needed ports?
Hi,   Our company no longer lets most users configure the windows firewall.  To use various Labview communications resources you need to have various ports open.  Our wiz-bang security keeps them closed, and there is no feed back to let you know if they are closed, or if a program is trying to use them (unlike normal windows operations).   I have found good documentation that shows what needs to be opened for various resources. http://zone.ni.com/devzone/cda/tut/p/id/12402   I was thinking of building a program to test these out,  so that the administrators of the systems could test to see if they indeed opened the correct ports.  I was thinking of a program that just tries to use all the needed ports to communicate with a second computer on the network.  Then you could get a report back saying if any ports did not communicate succesfully.  What better to use to test for Labview's ability to communicate than Labview itself.   Has someone seen this already done?   Thanks for your input!
Active Participant
DirkW
Re: Has anyone made a program to check to see if firewall settings are allowing communications on needed ports?
You should post this question to the labVIEW forum as well, to get a good answer.
DirkW
Member
Doug-B
Hey Steve,
I have never tried this myself, but from what you have described I believe that would be a sound way to test the ports your firewall would be blocking. Let me know how it works.
Good Luck,
Doug B
Applications Engineer
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
