Industrial Communications
Connections from PCI-8532 to DeviceNet Micro-style connectors?
I am looking to connect a PCI-8532-equipped PC to some already existing processing equipment running on DeviceNet.  Are there any easy options (i.e., patch cables available) to convert the 9-pin D-sub from the PCI-8532 to DNet micro-style, or do I have to crimp my own connectors?  I have come up empty so far...
Shane.
(4,998 Views)
Shane,
I'm not too sure where you can find DeviceNet to DB9, as NI does not produce those types of cables. There are various DeviceNet to serial modules that require wiring. I suggest looking at Rockwell Automation products as they carry a lot of different cables for DeviceNet and you may find a DeviceNet to DB9 cable there.
Logan
Applications Engineering
(4,968 Views)
