NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
se_mark
Communicate with a controller with CANopen interface using EDS file
Dear Mr../ Mrs..
I have almost no experience with CANopen network. I have a motor controller from Festo with a CANopen interface and the EDS file for it. Furthermore I have an USB-CAN converter from IXXAT and labview drivers for it. So I want to communicate and control this motor controller through the CANopen network - what is the easiest way getting around this problem? And which modules does it require?
I think, that I somehow can use the EDS-file. I can read and write keyvalues in the EDS-file using some basic vi's in labview, but I don't know how these values are transmitted to the controller - and how the controller changes the values in the EDS-file. But as I said I have no experience, so I don't know if this is a part of a solution at all.
Thanks in advance!
Best Regards
Søren
Member
A_A_ENG
Re: Communicate with a controller with CANopen interface using EDS file
Hi
Were you able to communicate with the Festo controller?
I have the same problem
I have a Festo controller and motor which I want to control throw Labview.
If you did it I would like to know how?
Did anyone else had a problem communicate with FESTO products?
Does anyone have any ideas how to do it?
Active Participant
DirkW
The CANopen USB adapter from XAAT uses CAN protocoll to communicate with the festo device. The EDS file is just a list of SDOs and PDOs the device supports for importing importing these requirements it into the Master software.
The EDS file is not an ective part in the communication. For detailed support for the API from IXXAT you should consider to call them or use there WEB support interface if they have one.
DirkW
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
