Industrial Communications
CanOPEN cRIO-9067 & LabVIEW 2014 support
We have cRIO-9067 and NI 9881 CANOpen communication module.
According to the NI 9881 product description page the module should work with cRIO-9067. However, the latest NI-Industrial Communications for CANopen 1.0.3 doesn't support LabVIEW 2014 and NI RIO 14.0. This means we can't use cRIO-9067, can we? If so, when the next release of the driver will be availiable? Will it work with cRIO-9030?
Thank you in advance,
Nikita.
Nikita Prorekhin
CLA
(6,166 Views)
Hi Nikita,
This is an error on the webpage.  Currently, it should actually read:
  • The NI 9881 module requires the NI cRIO-911x/9068/908x chassis and the LabVIEW FPGA Module.
Support for the 906x and 903x targets will come with the NI-Industrial Communications for CANopen 14.5.  Typically, the release is around the time of the LabVIEW 2014 SP1 release.  I apologize for the inconvenience, and have reported this to the person in charge of the page to correct this error.
Thank you!
Matt S.
Industrial Communications Product Support Engineer
(6,160 Views)
Hi Matt,
Thank you for your prompt reply.
Nikita.
Nikita Prorekhin
CLA
(6,155 Views)
Accepted by topic author NikitaProrekhin
Hi Nikita,
I wanted to let you know that support for the cRIO-9067 is available: http://www.ni.com/download/ni-industrial-communications-for-canopen-14.5/5234/en/
Thank you!
Matt S.
(5,570 Views)
Matt,
Thank you for the update!
Kind regards,
Nikita.
Nikita Prorekhin
CLA
(5,460 Views)
