12-15-2014 01:57 AM
We have cRIO-9067 and NI 9881 CANOpen communication module.
According to the NI 9881 product description page the module should work with cRIO-9067. However, the latest NI-Industrial Communications for CANopen 1.0.3 doesn't support LabVIEW 2014 and NI RIO 14.0. This means we can't use cRIO-9067, can we? If so, when the next release of the driver will be availiable? Will it work with cRIO-9030?
Thank you in advance,
Nikita.
12-15-2014 08:40 AM
Hi Nikita,
This is an error on the webpage. Currently, it should actually read:
Support for the 906x and 903x targets will come with the NI-Industrial Communications for CANopen 14.5. Typically, the release is around the time of the LabVIEW 2014 SP1 release. I apologize for the inconvenience, and have reported this to the person in charge of the page to correct this error.
Thank you!
12-15-2014 08:52 AM
Hi Matt,
Thank you for your prompt reply.
Nikita.
03-20-2015 12:46 PM
Hi Nikita,
I wanted to let you know that support for the cRIO-9067 is available: http://www.ni.com/download/ni-industrial-communications-for-canopen-14.5/5234/en/
Thank you!
04-08-2015 02:00 AM
Matt,
Thank you for the update!
Kind regards,
Nikita.
