06-25-2014 01:34 PM
9144 Chassis offers among others, the "EtherCAT State" signal, which is available as 8-bit UINT number.
What is the relationship between this number and EtherCAT states (init, pre-op, safe-op, operational and bootstrap)?
Or if it has some other meaning, what's the meaning?
Jerry Kowal
06-26-2014 03:16 AM
Below attached the map.
Note:usually, using LabVIEW, one should get/set the slave state by Programmatic API node without knowing the number.
06-26-2014 08:08 AM
Zhou,
That's what I've been looking for.
I could not find this information anywhere and at the moment I don't have an access to the hardware so I could not check it myself. .
My plan is to monitor the EtherCat state on the FPGA and manage hardware outputs based on it.
Yarek
