NI Home
Cart Cart | Help
You are here:
Reply
Member
hsowen
Accepted Solution
What does Amber ACTIVE indicator mean on 5641?
I am seeing an ACTIVE indicator light sometimes when running a VI on my 5641R.  It is not always present.  In the 5641R getting started guide, it indicates that an Amber light is not used for the ACTIVE indicator.  Is there any meaning to this light being Amber?
Member
dsangree
Re: What does Amber ACTIVE indicator mean on 5641?
[ Edited ]
It appears as though the documentation is out of date. In fact, it looks like the Active LED turns Amber when either of the DAC outputs are enabled or when the Aux DIO port is enabled (any of the pins individually enabled). So basically, it is Amber when the PXIe-5641R is outputting.
Member
hsowen
Ah ... makes sense.  Thanks for the response.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
