Hi Ran,
I do not believe what you have describe is possible for two reasons.
- You cannot run the instrument driver bitfile at the same time as a user defined FPGA bit file
- The AO ports are AC coupled so you will not be able to generate a DC bias on them.
JaceD
Signal Sources Product Support Engineer
