06-01-2010 01:05 AM
How I can run FPGA VI in Emulation mode in Labview 2009 so that I can run FPGA VI before compiling it?
Thanks and Regards,
Rashid
06-01-2010 11:48 AM - edited 06-01-2010 11:52 AM
Hello Rashid,
Do you have an 5640R or another R-Series based board? I am going to assume your FPGA VI makes hardware calls to a 5640R because of the forum in which you have posted. If this is the case, due to the architecture of the template Vis, emulation mode is not supported in NI-5640R. If you wish to emulate your logic and no hardware calls this is possible but this can also be done in a host vi.
06-01-2010 11:41 PM
Thanks ColeTrain.
Yes I am using NI PCI-5640R and my FPGA VI makes hardware calls to PCI-5640R.
Rashid
