02-11-2007 11:19 PM
I am working with a few others to convert some LabVIEW 7.1 code for cRIO over to LabVIEW 8.2 and am running into trouble. We have isolated the source of the problem to CAN. For the application, we are using two cRIO-9853 modules. The rest of our FPGA nd I/O run fine. We have confirmed this by running versions of the code without any CAN FPGA I/O blocks. With the CAN I/O blocks, the FPGA updates very very slowly.
We tried running the “CAN Basic.lvproj” available from the Example files with LabVIEW 8.20, updated to our
Error 65538 occurred at an unidentified location
Possible reason(s):
CompactRIO: (Hex 0x10002) The operation failed to complete in time. Make sure the module is not busy and the system is configured properly.
We have updated the software on the cRIO to 8.2 Is there something else we need to do to configure the FPGA or CAN modules?
Any help would be appreciated.
Thanks!
02-11-2007 11:51 PM
12-19-2011 04:55 PM
I was trying to perform the CAN Basic example on a 9853 as well. This is my first CAN project, so I just wanted to do the loopback in order to see that I can send and receive messages. I get the same error as above for my "Read" I/O node. Any suggestions??
12-19-2011 05:04 PM
This forum is for IF-RIO only. You will likely have better luck asking your cRIO question in the Real Time Measurement Board: http://forums.ni.com/t5/Real-Time-Measurement-and/
That board covers: cRIO, R Series, FlexRIO, and sbRIO
12-19-2011 05:35 PM
Sorry, thanks!
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
