Reply
How can I amplify my signal digitaly using 5641R
Go to Solution
Hello I am using 5641 R Transceiver and 5600,  5610 to down up converters. What  I wanna do is:
-downconvert the incoming signal an UMTS signal (with a power density of about -80dBm)
-using the FPGA I want to amplify the signal
-upconvert the signal
-transmit the amplified signal
I am compiling a really simple FPGA code to introduce a configurable linear gain
It works ok with a DIGITAL gain   up to 2 (linear scale) but if I multiply the incoming signal with a higher value, the output power doesnt increase
I know I can use down and upconverter gain, but I also want to digitaly amplify the signal. (I want to get a power near -1.5 dbm at the output of the IF Transceiver, that is the maximium output according with specifications)
why is the maxomium scale factor 2 ??
(also the VI "NI 5640  DAC Config IQ" has an input called "output scaled factor", and its maximium value is 2 )
any advise?
Jonathan Rueda
Message 1 of 4 (4,231 Views)
Reply
Highlighted
Re: How can I amplify my signal digitally using 5641R
Hi I just realize that each multiplier can produce a gain of 2, next time I will try before asking, but still components should be more intelligent than users Smiley Happy
Message 2 of 4 (4,225 Views)
Reply
Accepted by topic author CJRueda
‎08-27-2015 06:09 PM
Were you starting from one of the examples? I am not sure which multiplier you are talking about. If you are talking about the multiplier from the Process Data VI in the Analog Input and Output example, then it is not limited to multiply by 2. The reason it may seem that way is that the fixed point number that you are scaling by has been configured to have a word length of 18bits and a integer word length of 1bit. This means that the range would be 0-2 with a resolution of 7.6294e-6. You can right click on the fixed point number control and change this representation to have a different integer word length. For a given "Word Length", increasing the "Integer Word Length" will widen the range of values, but decrease the resolution that you can achieve.
Hope that helps. Let me know if I didn't understand your problem correctly.
Message 3 of 4 (4,221 Views)
I am adding a AGC to my solution.  That was exactly my problem. Thankyou!
Message 4 of 4 (4,217 Views)
Reply
