I am Sreenivasulu.
I have started working on NI-5640R LabVIEW card.I am able to do simulations using
labview8.2. But I am unable to interact with NI-5640R to get the
output through output ports.I studied the manual given by NI. But I am confused fully
with the procedure and i did not understand.I tried the example projects ni5640R,but I
failed.
So please tell me the procedure to be followed, how the ni5640R card ADC and DAC
working(how to give I/P to ADC and how to get the O/P from DAC),and how to interface
host(my PC)and Target(ni5640R) using VIs.
Please tell me that how the signal flows(inter connection between)through the parts of
VI(both in HOST and FPGA modules).
Final my goal is i need to generate modulated(AM,FM,FSk,BPSK,QPSK Etc) signal with Fc
21.4MHz for providing as a input to other module(RAD-2,Pentaland).
plz tell me can i get this by using LabVIEWmathscript or modulation tool kit Etc.
I am using LabVIEW 8.2 and card NI-5640R(PCI based) v 1.1
Thanking you so much sir.
Thanks & regards,
Sreenivasulu.O
