NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
xk104@sina.com
Accepted Solution
Dose NI PXIe-5641R have DRAM ?
Hello:
if it has,How many and How big?
why I could not got any clue on the NI PXIe-5641R specification?
Thanks your help
Member JVP
Member
JVP
Re: Dose NI PXIe-5641R have DRAM ?
Hello
The 5641R has one 128 MB of DRAM memory that is available to you from driver version 1.4 and up. In the project window if you right click on the FPGA Target you will have the following option:
A Memory Properties popup will appear when you select Memrory. In the Implementation option if you select DRAM, you will see all the options available to you. Please see the following image:
For more information please refer to the NI IF Transceivers Help. You can find this in the start menu under <National Instruments>\NI-5640R\Documentation\NI 5640R Help
In the help please refer to NI IF Transceivers Help >> Devices >> NI PXIe-5641R >> Configuring the Onboard DRAM Interface
This option is only available for LabVIEW FPGA.
Best Regards,
Jignesh P
Member
xk104@sina.com
回复: Dose NI PXIe-5641R have DRAM ?
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
