NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
arnova
5641R - ADC0 & ADC1 synchronisation / phase problem
We are trying to use a PXIe-5641R to acquire 2 analog signals fed into the 2 analog input channels (AI CH0/CH1). The FPGA generates complex FFTs for both channels and transfers them to PXIe-8106 CPU for further processing. Both the FPGA and the CPU are running custom code which was NOT developed by us and unfortunately the original author can't help us out. The problem is that the 2 ADC's are running out of sync which introduces random phase differences between the 2 channels for the complex FFTs generated by the FPGA. We have already figured out the problem must be somewhere near the ADC's and we suspect there's simply some parameter not properly configured "somewhere". We've also written a simple LabView test program which uses the 5641R's instrument driver (instead of using the custom FPGA code etc.) and then the ADC's ARE properly synchronised/in phase so it's not a hardware issue, as it seems.
Does anybody have an idea how to fix this issue? Any help would be highly appreciated.
Member JVP
Member
JVP
Re: 5641R - ADC0 & ADC1 synchronization / phase problem
Hello Arnova,
Can I have you look at a shipping example "ni 5640R Dual Channel Analog Input and Output". If you run that does the inputs have syncing problems? I think there may be something going on during the FFT calculations in FPGA. Can you also tell me a few pieces of information:
1) How much of a synchronization do you need?
2) What version of the drivers do you have?
3) What version of LabVIEW are you using?
4) How much of a phase difference are you seeing?
Best Regards,
Jignesh P
Member
arnova
[ Edited ]
Thanks for your reply.
Here are the answers for your questions:
1) I need as much synchronisation as possible. We're performing a complex FFT cross correlation of the 2 signals fed into Channel 0 & 1. The synchronisation we're getting when using the 564X in driver-mode (without our custom FPGA code) seems sufficient. I think this is roughly 1% drift.
2) I tried several. We first used the one that shipped with the system, I think it was 1.2. But we also tried the last one, 1.6
3) The system came with LabView 8.6 but I also tried LabView 2009SP1: no difference.
4) The phase difference seems completely different for each run, making me believe there's no synchronisation at all between channel 0 & 1 at the moment.
I searched the examples for "ni 5640R Dual Channel Analog Input and Output" but I was unable to find it. Any idea where I can find it?
I've also attached a picture of the code running in the FPGA. Note that I also tried connecting the input of both FFT loops to a single ADC (ADC0), just to make sure there's isn't any problem "upstream". Since this fixed the phase-issue, it made me believe the problem is "somewhere" in the ADC's configuration.
kind regards,
Arno van Amersfoort
Member
tigr
What about to try ADC-ing not in Asynchronous Wires Mode ? Just usual synchronous FPGA programming
Member
arnova
I'm a totally rookie when it comes to programming FPGA's with LabView (I do have a lot a experience with VHDL and of course "normal" Labview). Any pointers/examples how to implement that in my FPGA LabView code?
Member
tigr
Just like "Dual Channel Analog Input and Output" example (coming with 564x driver)
Member JVP
Member
JVP
Hello arnova,
The example I mentioned is in the same file path as the other examples:
<LabVIEW>\examples\instr\ni5640R
There are two directories in the ni5640R folder, Driver and FPGA, the example I mentioned is in the FPGA folder:
<LabVIEW>\examples\instr\ni5640R\FPGA\PXIe-5641R
Please let me know if you still can't find this example.
Best Regards,
Jignesh P
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
