NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
quantum5
When I run VAB on my laptop in DSP memeory mode I get: One or more of the object files you are linking with requires the driver to use the large memeory model. 15-bit .... How can i fix it?
When I try to run VAB on my dell laptop I get the following warning:
Warning: program not executable
15-bit displacement 3ffffe98 overflows. Located in _RTDSKDA.obj(.text), offset 00000060
How can I fix it?
Member
SAZ2
Re: When I run VAB on my laptop in DSP memeory mode I get: One or more of the object files you are linking with requires the driver to use the large memeory model. 15-bit .... How can i fix it?
You should check the Driver Globals, Compiler Options to see that the Far Aggragate Data option has been selected.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
