NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
ziggy
VAB installation issues with Media Center
I installed VAB on a new Media Center computer.  Half way through installation, it crashed.  Now if I try to install it I get the error that tells me to Uninstall and Unathorize through the help menu.  This will not work because it is not installed, and I cannot access the help due to it not being installed.  So, what do I do now?  Please help me!!!  Thanks,
Member SAZ
Member
SAZ
Re: VAB installation issues with Media Center
You can resolve this problem by manually deleting the Windows registry key that governs VAB's un-install process. You should find the Hyperception VAB key listed among the entries located at the following Windows registry path: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ You should verify that you have selected the proper key before deleting it from the registry -- if you used the default installation path then you will see a reference to \Program Files\Hyperception as the installation directory. Removing this key should allow the VAB installation to proceed. Regards, Steve
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
