NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
ziggy
My VAB example Files are associated with VisualStudio What should I do?
My VAB example Files are associated with VisualStudio.  When I try to launch an example it opens with VisualStudio.  When I use VAB to open an example no problems.  My associations do not seem to be correct, but I have tried reassociate the VAB files to VAB with no luck:smileymad:.   What should I do?
VAB version 1.3
Windows XP SP2
Windows 2000
Member SAZ
Member
SAZ
Re: My VAB example Files are associated with VisualStudio What should I do?
You should be able to manually setup the VAB file types (.LST and .LSS) through the Windows Control Panel. Select Folder Options from the Control Panel, and then select the File Types tab. Then search for the .LST and .LSS file extensions in the list of registered file types. Select the desired VAB file extension, and then choose the 'Opens with' Change option to select which program to use for these file extensions. That should correct the problem. Regards, Steve
Member SAZ
Member
SAZ
Forgot to mention that you'll want to select VAB as the program to use when opening either of these file types (i.e. .LST and .LSS). Regards, Steve
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
