NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
ziggy
In XP Infinity Blocks are missing when logged in as a user
On XP Computers when I am logger on as adminstrator there is no problem.  When my students are logged on as users, some of the Infinity Blocks are missing.
For example on Ch 2.1 Sec 2.2 lab, the ITOGGLE Block is a question mark.  I can search and find it, but there is no way to add it the VAB progam in place the question mark.
Can you help me out?  Thanks,
Member SAZ
Member
SAZ
Re: In XP Infinity Blocks are missing when logged in as a user
This problem is has to do with "security" (AKA file permissions) for some of the VAB files. I am not aware of what may have caused the problem. As the USER check to see what problem files exist. Then as the ADMINISTRATOR check the "Security" tab in the file's properties and you'll find that the USER is unable to modify/read/see/etc that file. Changing the setting to match one of the "OK" DLL block files should correct the problem. Alternatively you can run the command line script that the installer runs: cacls "C:\Program FIles\Hyperception\VABINF" /T /E /G Everyone:F Assuming you installed in the default directory, you should be able to drop to a command prompt and issue this command. It will scroll the name of every file in the given directory and all subdirectories. It should reset every file.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
