01-24-2012 10:28 AM
hello ,
i am new to ni digitizer cards. actually i am trying to develop an application for acquiring real time data using ni pci 5112.
i started with running the c example code " multi reacord.c" that is supplied with ni scope 3.6 on windows xp os.
i copied all available header files and library files in the "include/library" folders in tc(turbo c) folder.
but whenever i run this source code multirecord.c i get error " cannot open include asciiPlot.h"
though it is very available in the include folder.
i tried with other codes as well but i am facing similar problems.
kindly help to solve this problem.
09-23-2013 09:24 AM
vijay82,
The problem you have is most likely caused by your Turbo C IDE not configured properly. You will need to ensure that the "include/library" folder is included in the list of "include directories". I'm not familliar with TC, but I would imagine that these are on a settings page.
I hope this helps!
